Haas Parameter 251 A DOOR OPEN ERRTIME
Supports the Auto-Door feature. It is used for several things:
  • 1) It specifies the number of 50ths of a second for the motor to run to open the door.
  • 2) Parameter value plus one second specifies number of 50ths of a second for the motor to run to close the door.
  • 3) If, at the end of the door-close time, the door has not yet reached the switch, Alarm 238, Door Fault is generated.
