Haas Parameter 181 Sp MIN SLIP
Minimum value allowed from the slip rate. From the equation: Slip rate = slip gain x (speed/max speed) x (current/max current). It can be seen that at a zero speed, the slip rate would become zero; therefore, a minimum value for slip rate is required (16.384 = 1 Hz).
