Haas Alarm 964 TOOL TURRET ROTATE FAULT
Alarm: 964 TOOL TURRET ROTATE FAULT
The turret did not rotate to the correct location within the time specified in Parameter 60. Check for obstructions that would prevent the turret from rotating. Check the operation of the position sensors: slow, position_1, and in_position.
