Haas Alarm 923 LOW OIL PRESSURE – Haas Lathe
Alarm: 923 LOW OIL PRESSURE – Haas Lathe
Oil Pump for platter gear has no pressure. Check that pump is pumping oil through lines. Check to make sure filter next to pump is not plugged. Parameter 618 determines delay to check pressure after start.
