Haas Alarm 911 APC-PAL LOAD/UNLOAD AT ZERO – Haas Mill
Alarm: 911 APC-PAL LOAD/UNLOAD AT ZERO – Haas Mill
One or more of the pallets on the APC has a load or unload position set to zero. This means that the APC set up procedure was incomplete. Establish correct load and unload positions for all pallets and enter the positions in the appropriate settings. See operator’s manual for the APC model correct setting numbers.
