Haas Alarm: 226 Z TRANSITION FAULT
Illegal transition of encoder count pulses in Z-axis. This alarm usually indicates that the encoder has been damaged and encoder position data is unreliable. This can also be caused by loose connectors at the MOCON PCB.
