Haas Parameter 599 Ss ENC. SCALE FACTOR
This axis parameter works in place of the axis parameters SCALE/X LO and SCALE/X HI. If SCALE FACT/X is set to 1, the scale ratio is determined by SCALE/X LO and SCALE/X HI as follows:
HI LO
0 0 3
0 1 5
1 0 7
1 1 9
If, however, SCALE FACT/X is set to zero, the value of ENC. SCALE FACTOR is used for the scale ratio instead.
Note that any value outside the range of 1 to 100 will be ignored and the scale ratio will remain unaffected.
