Haas Parameter 587 EXTENDED PUSH TIME – Haas Lathe
Supports bar feeder pusher rod which is mounted on the bar feeder trolley (for bar feeders with 1-foot extension option). The units are 50th’s of a second. It causes a delay of the amount of time specified to enable the pusher rod to full extend before the trolley begins to travel back to the home position. This parameter should be set to 150 (3 seconds) on the SL-30 Big Bore and SL-40 only. For all other lathes, it should be set to zero. On older lathes without the pusher rod, this parameter will have no effect. Note also that with this change, the I/O board discrete output has been changed from #23 to #1.
