Manual operation in which a reference tool and the tool to be measured are pressed against a fixed point on the machine, one after the other, and the difference in length between the tools is set as a tool length offset value in the CNC.
More ...
Retracting a tool from the workpiece, allowing the tool to be exchanged during machining (if broken) or the state of machining to be checked, and subsequently repositioning the tool to…
Fanuc G43 G44 G49 Tool Length Compensation
G43 Tool Length Compensation positive With G43 a value from the offset register (OFFSET) can be called up and added to tool length. To all following Z movements (with active…
Selca G48 Recalls and enables tool length compensation
Selca G48 Recalls and enables tool length compensation Programming G48 [K…] [I…] Parameters Parameter Description K compensation number. I finish stock value. Note: program G48 I0 to disable the active…
Selca G817 Tool length offset on an axis non-orthogonal to the machining plane
Selca G817 Tool length offset on an axis non-orthogonal to the machining plane Programming G817 Axis Parameters Parameter Description Axis name of the machine axis to which the compensation is…
SINUMERIK – Definition from CNC Dictionary
The brand name for Siemens numerical controls.The name of the organizational unit of Siemens that designs and manufacturers numerical controls.
TV check – Definition from CNC Dictionary
Checking whether the total number of characters in a block (starting immediately after an end–of–block code and ending at the next end–of–block code) is even or odd.
TH check – Definition from CNC Dictionary
Checking whether the total number of 1 bits in a character is even or odd.
Subprogram – Definition from CNC Dictionary
Program that can be called repeatedly by the control section of another program.
A machine tool which does primarily turning, but which has live tooling (a spindle on the turret) for doing milling operations. From a software point of view, a turning center…
Stored stroke check – Definition from CNC Dictionary
Setting a forbidden area in the CNC for a tool, decelerating the tool to a stop, and issuing an alarm if the tool is about to enter the forbidden area.
Stored stroke limit – Definition from CNC Dictionary
See “Stored stroke check”
Stroke limit check before move – Definition from CNC Dictionary
Stroke limit check performed before the movement specified in a block is started.
Boring Bar Diameter to Length Ratio Recommendations for CNC Machinists
When doing any operation on a lathe, all parameters are critical and should not be overlooked. There are industry standards and recommendations for SFM, feedrates, insert geometry, workholding, etc., that…
Centroid G65 Macro Program for Slots of varying Depth and Length
;The main program would call this macro five times, ;each time specifying the depth and length required. ;macro variables would handle the length in the Y direction ;and depth in…
