Okuma Alarm-P 0996 PLC axis data file
The PLC axis control constants do not match the machine specifications.
Index
PLC axis name
1:U100->None
7030->The axis names downloaded from PLC axis data file do not match the actually mounted axis names.
2:U100->This file open error
7030->The file type is not “PBU1”.
3:U100->The file reading error(header,axis data1)
7030->The file has too large DB.
4:U100->The file attribute error (file affribute is not “PBU1”)
7030->The specification data in the PLC axis data file is different from that in the SVP data file.
5:U100->The file closed error
7030->Memory location table of the axis backup data of the PLC axis data file is not found.
6:U100->The file has too large.
7030->Memory location table of the axis parameters of the PLC axis data file is not found.
7:U100->The file reading error(axis data2,3)
7030->An error occurred when opening the PLC axis data file. File is short.
File name or device name is incorrect.
8:U100->The axis name unjust error.
7030->Although the axis name in the PLC axis data file is the Okuma specification name, it differs from the registered name.
9:PLC axis data file is too small.
15:The number of PLC axes exceeds 8.
16:PLC axis number exceeds 8.
17:Rotary axis gear transmission ratio of the master axis is 0 although the axis hangeover specification (function generation specification B bit 0) is set.
18:Rotary axis gear transmission ratio of the slave axis is 0 although the axis changeover specification (function generation specification B bit 0) is set.
19:Pitch data of the master axis is 0 although the axis changeover specification (function generation specification B bit 0) is set.
1A:Pitch data of the slave axis is 0 although the axis changeover specification (function generation specification B bit 0) is set.
1B:Rotary axis specification (servo data file) is not set although the point positioning specification (function generation specification B bit 6) is set.
1C:Linear axis specification (servo data file) is not set although the arbitrary positioning specification (function generation specification B bit 7) is set.
1D:For OSP7030 / OSP730, the master axis of the axes with an independent position sensor is not found, or the master axis is not set.
1E:For OSP7030 / OSP730, multiple axes are specified as the master axis of the axes with an independent position sensor.
1F:For OSP7030 / OSP730, detected speed of the axis with an independent position sensor is 0.
This data is set by MCS when the power is turned on.
20:For OSP7030 / OSP730, the rotary axis gear transmission ratio (EQDGT) or the convert factor (ESRDGT) of the axis with an independent position sensor is not set. (setting value: 0)
21:For OSP7030 / OSP730, it was designated in concurrense with the axis changeover specification and the table changeover specification
Error in creation of PLC axis data file
21…Power is shut off during axis changeover control.
