Okuma Alarm-P 0992 PLC backup data file read
The PLC backup data or M code data file cannot be read from the memory.
Concerning the ATC or ACC machine, logical-data-file does not read.
Concerning the 1CAM-ATC machine,
The command-table-data-file does not be read.
20001->The M code data file is not found or a wrong file name is specified.
20002->The M code data file cannot open.
30001->The logical-data-file is not found.
Or file name is wrong
30002->The logical-data-file is cannot open.
None->M code data file error
1->The PLC backup data file is not found or a wrong file name is specified.
2->The PLC backup data file cannot open.
3->The command-table-data-file does not be read.
1)If the alarm occurred during normal NC operation, the file has been deleted or its data has been destroyed.
2)If the alarm occurred without NC operation after installation of control software, the file type was wrong or no such file was stored in the memory.
1)In the case of 1), reinstall the control software.
2)In the case of 2), check the control floppy disk data and recreate the floppy disk.
