Okuma Alarm-D 4101 CAS software environment being changed
The control parameter of the CAS software is being changing initialized. Under such a condition, it cannot be works.
1-> It is final product output processing.
2-> The cutting mode is switched and it is processing it.
3-> The change in the interference setting it is off the subject parameters is being processed.
4-> The change in the material display setting mode specification parameter is being processed.
5-> The material the re-reading is being processed.
6-> The change of the parameter for the CAS is being processed.
Expected faulty point
When the interference check is done to the completion of initialization, it is generated.
Treatment measures
It is made to operate after initialization is completed.
