Okuma Alarm-B 2703 Chucking miss
The chucking error detecting function found a chucking condition unsatisfied.
1->Though chucking error detection ON command (M133) was given, the air pressure switch failed to come ON.
2->When the chucking error detection ON command was given, the pressure switch input had been ON.
3->The grip limit switch did not correctly function when the grip confirmation unit was advanced by a chucking miss sensor ON command (M133).
4->Though Tailstock chucking error detection ON command (M433) was given, the air pressure switch failed to come ON.
5->Though 2nd chucking error detection ON command (M633) was given, the air pressure switch failed to come ON.
6->Tailstock tool chucking error detection ON command(M1191) was given, the air pressure switch failed to come ON.
Workpiece is not clamped in the chuck correctly.
Check the workpiece chucked condition.
