Okuma Alarm-B 2549 Tool no. mismatch after ATC sequence restart
By a restart function, when it returned a sequence, it was about to return a sequence the program which TL command which calculates the tool number that there is not on Turret or TG command has performed.
ZZ->A tool number
FFFFFFFF->In TOOL-ID spec, TL-command that divided tool-number that there is not in turret is performed.
Make a tool of the block which resumes a sequence please coincide with the tool which is installed on Turret when it returns a sequence.
