Okuma Alarm-B 2530 Machining process instruction no.
Machining process instruction number (VWORK) from loader is the outside of range (VWORK<0, VW ORK>99). Or, at the machining process instruction number which differed from A Turret in B
Turret command is designated.
XXXXXXXX (hexadecimal)
XXXXXXXX:An input machining process instruction number
None:At the machining process instruction number which differed from A Turret in B Turret command is designated
Instruction miss of a machining process instruction number
A machining process instruction number correction
