Okuma Alarm-B 2513 Coordinate calculation
Coordinates calculation command is wrong.
1->It instructed in Coordinates calculation oder as follows.
It is not a coordinates calculation specification.
During the cutter radius compensation mode
(Nose radius compensation mode)
Lap mode
Arbitrary angle chamfering
NO Y axis mode
G02/G03
2->I instruction is outside the range.
LAA/GRDX(Y)/DGRDX(Y)/SQRX(Y)
-99999.999 <= I <= 99999.999[mm]
BHC/ARC
0.001 <= I <= 99999.999[mm]
3->J instruction is outside the range.
LAA/BHC/ARC
-359.999 <= J <= 359.999[deg.]
-99999.999 <= J <= 99999.999[mm]
4->K instruction is outside the range.
LAA/GRDX(Y)/DGRDX(Y)/SQRX(Y)/ARC
1 <= K <= 65535
BHC
-65535 <= K <= 65535(excluding 0)
5->D instruction is outside the range.
1 <= D <= 65535
6->Q instruction is outside the range.
DGRDX(Y)
-99999.999 <= Q <= 99999.999[mm]
ARC
-359.999 <= Q <= 359.999[deg.]
7->R instruction is outside the range.
DGRDX(Y)
-99999.999 <= R <= 99999.999[mm]
LOMIT/RSTRT
1 <= K <= 65535
11->The number of the interval of the LAA/ARC instruction is the number of (10) maximum excess.
12->The pattern point is the number of (65535) maximum excess.
13->R number of LOMIT is the number of (30) maximum excess.
14->It is not I, and is no K, and it is neither LAA instruction nor order of I and K there is no I instruction.
It is not Q, and is no K, and it is neither ARC instruction nor order of Q and K there is no Q instruction.
Incorrect program
The program is reviewed.
