Okuma Alarm-B 2424 MULTI-MACHINING CYCLE Feed G94
G185 through G188 is designated in the G94 (feedrate in m/min) mode.
G185: Thread cutting cycle (side face)
G186: Thread cutting cycle (end face)
G187: Straight thread cutting cycle (side face)
G188: Straight thread cutting cycle (end face)
G94: Feed per minute mode (mm/min)
Faulty program (compound fixed cycle block)
Program Example:
G185 G94 X95 Z60 C0 F10 SA=12
Designate the G95 command so that the compound fixed cycle block (G185 – G188) is in the G95 mode.
G185 G95 X95 Z60 C0 F10 SA=12
Related Specifications
Multi-machining model
