Okuma Alarm-B 2416 MULTI-MACHINING CYCLE C
Programmed C value is not: -360-deg < C < 360-deg.Object
Hexadecimal number of designated C value
Faulty program (compound fixed cycle block)
Program Example:
G181 X60 Z75 C360 K48 F40
Check the C command in the compound fixed cycle block.
G181 X60 Z75 C0 K48 F40
Related Specifications
Multi-machining model
