Okuma Alarm-B 2408 MULTI CYCLE Width
In the G73, G74 grooving cycle, the tool width calculated from the tool offset value is larger than the groove width.
G73: Compound grooving cycle on side face
G74: Compound grooving cycle on end face
Hexadecimal number of final grooving amount
Program error
Setting of improper tool offset value
Program Example:
N009 G00 X100 Z100 T101
N010 G73 X50 Z70 I10 K4 D15 L30 T02
T1 Z10.000
T2 Z60.000
Check the tool offset value or the tool offset command. For the example program, change the tool offset value for T2.
T2 Z15.000
