Okuma Alarm-B 2362 NOSE-R COMP. Cancel G00 G01
Code G40 canceling tool nose radius compensation mode is designated in other than the G00 or G01 mode.
Program error
Program Example:N010 G40 G02 X– Z– I–
Check the position of the G40 command; nose R compensation should be canceled only in the G00 or G01 mode.
In the example program above, the nose R compensation mode is canceled in the G02 mode; correct the program so that the cancel is made in the specified interpolation mode.
N010 G02 X-- Z-- I--
N011 G40G00 X--
