Okuma Alarm-B 2319 READ/WRITE Data
Data in a READ/WRITE command is wrong.
1->Parity error in READ operation
2->Transmission end code in WRITE data
Hardware
Parameter setting error
Program error
1)Replace the RS232C interface.
2)Check the parameter setting.
The transfer end code can be chosen between % (1) and NULL (0) by setting data at the OPTIONAL PARAMETER
(EXTERNAL I/O)
Program end code.
3)Check the program.
Related Specifications
User task 2
