Okuma Alarm-B 2317 READ/WRITE Buffer over
Data size exceeds 160 bytes when READ/WRITE command is executed.
1->Alarm during execution of READ command
2->Alarm during execution of WRITE command
Program error
Program Example:
PUT ‘AB’
PUT ‘AB’
: 80 lines
PUT ‘AB’
PUT ‘AB’
WRITE 1
One character is expressed in a code consisting of 7 bits.
To distinguish roman characters from katakana, SI (shift in) code is put in front of a roman character while SO (shift out) code in front of katakana. If, however, roman characters (or katakana) come in succession, SI (or SO) code is not attached to each of the characters. In the above program, SI code is put at the head of the data, and so the data size exceeded 161 bytes, resulting in this alarm.
Check the GET/PUT command.
PUT ‘AB’
PUT ‘AB’
PUT ‘AB’79 lines
PUT ‘AB’
WRITE 1
Related Specifications
User task 2
