Okuma Alarm-B 2310 UGC Command over
Overflow of user graphic command stack area
1->An overflow occurs in the temporary storage area for user graphic command string.
User graphic command string
Program Example:
*DEF
*END
*-*More than 600 bytes
Reduce the number of the commands in the command-string, or reduce the necessary memory space using the macro.
*DEF
*END
*-*Reduce to less than 600 bytes
Related Specifications
Graphic
