Okuma Alarm-A 1329 Shift amount error
The shift amount is unsuitable.
1->The shift amount is not 0 although shift amount is not overlapped.
2->The CON value fell to a negative value after addition of shift amount.
3->The CON value exceeded the plus variable limit after addition of shift amount.
4->The CON value exceeded the minus variable limit after addition of shift amount.
5->The shift amount does not solidarity in the anticus which turns a shift amount into a fixation state and posterior.
