Okuma Alarm-A 1107 Major FL-net error
A serious error occurred during startup of the FL-net card.
Y000XXXX
When Y=0, XXXX=7F00 System error
7F01 Flash memory error
7F02 DRAM test error
7F03 NICE test error
7F04 EEPROM sum check error
7F05 CPU BUS error
7F06 Illegal instruction
If Y=1, XXXX = 4000. Timeout error of 4 sec or longer
If Y=2, XXXX : CommonMemory busy count
When Y=3, XXXX=State of self node
bit 3: Double detection of common memory bit address
bit 4: Double detection of common memory word address
bit 6: Token monitor timeout error
bit 7: Double detection of self node number
FL-net card is defective.
