Sandvik Coromant Machining Calculator App for CNC Machinist
By Date April 4, 2012
Another mobile app is discussed here Seco Tools Assistant Mobile App for CNC Machinist.
You want to calculate the tool cutting speed or spindle speed or just want to calculate the time a given operation will take, then here is an iPhone/Android/Blackberry mobile app for you. This mobile app can be useful in cnc workshop for a cnc-machinist/cnc-setter. This mobile app is from Sandvik Coromant.
The Machining Calculator from Sandvik Coromant is designed to help engineers and machinists optimize the performance of their turning, milling and drilling applications by calculating optimal cut settings based on job parameters.
Sandvik Coromant Machining Calculator App is very easy to operate, just enter the input values and the results will show up.
Parameter descriptions can be found in the Information page, your preferences can be changed in Settings.
Try Advanced mode for more detailed calculations.
Sandvik Coromant Machining Calculator App working
Sandvik Coromant machining calculator app gives us lot more useful data than the Seco Tools Assistant Mobile App, but Seco Tools Assistant Mobile App works well what it is suppose to do. The Sandvik Coromant Machining Calculator App goes a bit further, this mobile app calculates
  • Cutting Speed (vc)
  • Spindle Speed
The added functionality in this mobile app is the machining calculator.
With Sandvik Coromant Machining Calculator App you can calculate the machining time of an operation.
If you give Rough diameter and finish diameter and depth of cut then Sandvik Coromant Machining Calculator App will calculate the number of passes the tool will take to complete the machining operation.
Not only this if you give feed and cutting speed it will calculate the total operation time and also the operation time in seconds of every machining pass.
The Sandvik Coromant Machining Calculator App calculates even more useful data for a cnc machinist.
No doubt the Sandvik Coromant Machining Calculator App is worth checking.
Download Links for Sandvik Coromant Machining Calculator App
