Okuma Alarm-P 0994 TCP/IP configuration file
The TCP/IP configuration file has an error.
1->No configuration file
2->Configuration file attribute error
3->An error occurred when the configuration file was opened.
4->A wrong IP Address is specified at the destination station.
5->A wrong port number is specified at the destination station.
6->A wrong port number is specified at the current station.
7->Logging ON or OFF is wrongly specified.
8->A wrong IP Address is specified at the current station.
9->The net mask is wrongly specified.
A->The broadcast address is wrongly specified.
B->Presence/absence of the operation file name is wrongly specified. The following are the error codes related to TCP/IP
driver.
C->Sector device designation error
D->Sector device has not been set.
E->Descriptor error
F->Parameter setting error
2E->Specified configuration file not found
2F->Configuration file opening error
30->Configuration file closing error
31->Configuration file read error
32->No data in configuration file
33->Wrong IP Address
34->No IP Address
40->A size of OMRON communication parameter is small.
41->Wrong setting of OMRON communication parameter.
