Okuma Alarm-P 0822 Wheel data file read
At power on, the wheel data pair number extension file (GNCUD*.PBU) cannot be read from memory (sector device MD0A:) correctly.
1 ->The file is not stored in memory, or file name is different.
2 ->The file type is not “PBU3”.
3 ->File DB size is too large.
4 ->File DB side is too small.
1 The wheel data pair number extension file is not stored in the floppy disk shipped with the NC.
2)Operation procedure for loading the PBU file from the floppy disk to the NC memory is incorrect.
(A COPY command must not be used.)
3)Memory error
1)Check the control floppy disk if the wheel data pair number extension file (GNCUD*.PBU) is stored on it.
2)Load the control floppy disk again.
3)Replace the memory.
