Okuma Alarm-P 0739 MCS DD encoder (slave sensor) initialization failure
An error occurred in the initialization of the DD encoder (slave sensor).
Axis name or none (spindle)
XX = Encoder link initialization sequence number (1B) at the time of the error detection
0: Reset
1: Network address setting
2: Request to send the basic information for communication
3: Change of communication software version
5: Parameter change
6: Position detection start
7: AT mode start
YY = Error content (1B)
0: Communication error
3: Reception finish time over
4: Abnormal response address
5: Abnormal response code
6: Parameter error
ZZZZ = Data (2B)
If YY = 0,
The encoder link error status C2ERR at the time of error detection appears.
If YY = 1, 2 or 3,
The transmitted frame information QC2MTINF appears.
If YY = 4,
The network address of the responding device appears.
If YY = 5,
Alarm code + positional data status
Refer to MCS DD Encoder error (alarm 1136).
If YY = 6,
Parameter number at which the error is detected
1: Reception of insufficient number of parameters
2: Basic information for communication being incompatible
3: Multi-turn detection range over
4: Communication protocol version being incompatible
5: Positional data format being incompatible
6: Abbreviated data mode being incompatible
However, when abnormal voltage is detected at the encoder fuse
XXYY = $FFFF fixed
ZZZZ = Detected voltage value of the encoder fuse (12[V] = $9980)
Normal range: 10.6[V] to 13.8[V]
Allowable range: $8800 to $B000
Encoder link cables and connectors
Inverter unit control board
