Okuma Alarm-B 2500 MULTI-MACHINING CYCLE HS,HI,HJ,HK
HS/HI/HJ/HK command is wrong.
1->Y axis was instructed in by the HS instruction when it was not Y axis mode.
2->HJ was instructed in when it was not Y axis mode.
3->There are HS, HI or neither HJ nor HK instructions.
4->HK was instructed in when HI was instructed when the side was processed or the front was processed.
5-> HS/HI/HJ/HK instruction is outside the range.
-99999.999 <= H? <= 99999.999[mm]
Incorrect program
The program is reviewed.
