Okuma Alarm-B 2489 NC tailstock parameter error
There is an error in the NC tailstock parameter.
1->There is an error in the multiple sizing position command.
2->[RETRACT] is set as a back side more than [W-axis Plus limit].
3->[APPROACH] is set as a back side more than [RETRACT].
4->A torque monitroring system is invalid in case of.
[APPROACH] is set as the front side more than [WORK POSITION]+[+OK]+2mm.
A torque monitroring ststem is effective in case of.
[APPROACH] is set as the front side more than [WORK POSITION]+[+OK]+[CENTER HOLE]+5mm.
5->[WORK POSITION]-[-OK] is set as the front side more than [W-axis Minus limit].
6->[THRUST] is zero.
7->[APPROACH] is set as a back side more than [W-axis Plus limit] in Teachmode.
NC Tailstock prameter
NC Tailstock prameter setting
