Okuma Alarm-B 2423 MULTI-MACHINING CYCLE SA
Designated SA value is not: 0 < SA <= 20
No SA command
SA: C-axis rotation command
FFFFFFFF->No SA command
Others:Hexadecimal number of designated SA value
Faulty program (compound fixed cycle block)
Program Example:
G185 X95 Z60 C0 F10 SA=30
Check the SA command in the compound fixed cycle block.
G185 X95 Z60 C0 F10 SA=20
Related Specifications
Multi-machining model
