Okuma Alarm-B 2287 Minus variable limit over
The target point of the designated axis movement command is smaller than the variable limit position in the negative direction.
AXIS
1->The target point of the designated axis movement command
2->The designated return point of the multi-machining cycle
8->It was commanded over movable range minus limit for X/Y/Z axis in executing G00/G01/G30, when “the touch setter measurement function” was effective and “the stroke end limit”was not effective.
1)Change the command to a value greater than the variable limit value in the negative direction.
2)Check the zero offset value.
3)Check the tool offset value.
