Okuma Alarm-B 2202 Common variable error
An improper common variable is specified.
Common variables other than V1 – V32 and V901 – V932 cannot be used.
Specified variable number in hexadecimal
None->Characters other than alphanumerics are designated following address character V, or V0 is programmed.
Others->The specified variable number is outside the following ranges: 1 =< V =< 32, 901 =< V =< 932
Common variable
Program Example:
V0=13 — Code None
V45=20Code — 2D (Hexadecimal of 45)
Correct designation of a common variable.
Example:
V12=50
V902=25
