Checking whether the total number of 1 bits in a character is even or odd.
TH check – Definition from CNC Dictionary
More ...
TV check – Definition from CNC Dictionary
Checking whether the total number of characters in a block (starting immediately after an end–of–block code and ending at the next end–of–block code) is even or odd.
Stored stroke check – Definition from CNC Dictionary
Setting a forbidden area in the CNC for a tool, decelerating the tool to a stop, and issuing an alarm if the tool is about to enter the forbidden area.
Stroke limit check before move – Definition from CNC Dictionary
Stroke limit check performed before the movement specified in a block is started.
SINUMERIK – Definition from CNC Dictionary
The brand name for Siemens numerical controls.The name of the organizational unit of Siemens that designs and manufacturers numerical controls.
Subprogram – Definition from CNC Dictionary
Program that can be called repeatedly by the control section of another program.
A machine tool which does primarily turning, but which has live tooling (a spindle on the turret) for doing milling operations. From a software point of view, a turning center…
Retracting a tool from the workpiece, allowing the tool to be exchanged during machining (if broken) or the state of machining to be checked, and subsequently repositioning the tool to…
Manual operation in which a reference tool and the tool to be measured are pressed against a fixed point on the machine, one after the other, and the difference in length between…
Stored stroke limit – Definition from CNC Dictionary
See “Stored stroke check”
Selca G997 G998 Block sequence number check
Selca G997 G998 Block sequence number check G997 Cancels G998 G997 Cancels G998 (Only for S3000 Series CNCs) Programming G997 G998 Block sequence number check G998 Block sequence number check…
Selca G879 Closing of limit definition
Selca G879 Closing of limit definition Programming G879 [I…] [J…] [Q…] Parameters Parameter Description I probe axis upper limit in copying mode 5. J probe axis lower limit in copying…
Selca G62 Type of coordinates for the definition of circle center in G2/G3
Selca G62 Type of coordinates for the definition of circle center in G2/G3 Programming G62 K… Parameters Parameter Description K type of coordinates. K1 absolute coordinates. K2 incremental coordinates, with…
CNC Lathe Live Tooling Definition and Related Haas CNC M-Codes
CNC Lathe Live Tooling Definition The cnc lathe live tooling option allows you to drive axial or radial driven tools to perform such secondary operations as drilling or tapping, both on…
