Stroke limit check performed before the movement specified in a block is started.
Stroke limit check before move – Definition from CNC Dictionary
More ...
Stored stroke check – Definition from CNC Dictionary
Setting a forbidden area in the CNC for a tool, decelerating the tool to a stop, and issuing an alarm if the tool is about to enter the forbidden area.
Stored stroke limit – Definition from CNC Dictionary
See “Stored stroke check”
TV check – Definition from CNC Dictionary
Checking whether the total number of characters in a block (starting immediately after an end–of–block code and ending at the next end–of–block code) is even or odd.
TH check – Definition from CNC Dictionary
Checking whether the total number of 1 bits in a character is even or odd.
SINUMERIK – Definition from CNC Dictionary
The brand name for Siemens numerical controls.The name of the organizational unit of Siemens that designs and manufacturers numerical controls.
Subprogram – Definition from CNC Dictionary
Program that can be called repeatedly by the control section of another program.
A machine tool which does primarily turning, but which has live tooling (a spindle on the turret) for doing milling operations. From a software point of view, a turning center…
Selca G879 Closing of limit definition
Selca G879 Closing of limit definition Programming G879 [I…] [J…] [Q…] Parameters Parameter Description I probe axis upper limit in copying mode 5. J probe axis lower limit in copying…
Retracting a tool from the workpiece, allowing the tool to be exchanged during machining (if broken) or the state of machining to be checked, and subsequently repositioning the tool to…
Manual operation in which a reference tool and the tool to be measured are pressed against a fixed point on the machine, one after the other, and the difference in length between…
Selca G997 G998 Block sequence number check
Selca G997 G998 Block sequence number check G997 Cancels G998 G997 Cancels G998 (Only for S3000 Series CNCs) Programming G997 G998 Block sequence number check G998 Block sequence number check…
Move Machine in Workshop with DIY Machine Skates – Basic Rigging
You bought a (cnc) machine for your workshop, or you just want to move machine to a new corner in workshop. Here is a very basic technique to move machine….
Osai SSL – Spindle Speed Limit Command
Osai 10 Series command SSL is used with G96 to set the maximum rpm that the spindle is allowed to run during CSS. Programming SSL=value Parameters Parameter Description value Is…
Selca G910 G911 Disables travel limit control
Selca G910 G911 Disables travel limit control G910 Cancels G911 G910 Cancels G911 Programming G910 G911 Disables travel limit control G911 Disables travel limit control Programming G911 The block containing…
