Mazak Alarm 267 BALL SCREW X44C LUBRICATION ALARM
Description
The pressure switch (SP7) for ball screw and C-axis gear lubrication does not turn on or off within a fixed time.
The float switch (SL1) has turned off.
Check and remedy
Check the lubrication oil level, and replenish lubricating oil if required.
