Fill in the blank CNC Programming Exercise Multiple Arcs
A cnc mill programming exercise with multiple arc joint together.
This cnc programming exercise shows how to make program for the components which have multiple arcs, so cnc programmer have to use multiple Circular Interpolation G codes G02 G03.
How to Solve?
A drawing is given below with it’s complete cnc program, but some of the program blocks have missing numbers, you just have to fill those with correct values, a check mark will appear if correct program value is input.
Note: this is an Adobe Flash tutorial.
