Yasnac Alarm 515 CIRCULAR ARC PROGRAMMING ERROR (G02/G03)
Yasnac Alarm Description
I, J, K and R are mixedly commanded in programming circular arc. Radius value is zero or not specified though the end point of circular arc is designated. The plane for circular interpolation is not defined caused by erroneous designation. (For example, circular arc is designated in three axes.) in programming R designating circular arc, R value from which the center point cannot be obtained is commanded: R < distance between start point and end point / 2. the above R value causes error.
Applies to
Yasnac CNC Controls 3000G
