Yasnac Alarm 23 ZERO RETURN UNREADY
3000G Alarm 23 REFERENCE ZERO RETURN UNREADY
Yasnac Alarm Description
Cycle start push button is depressed before performing zero return with the control interlocked for zero return. (parameter no. 66 = “1”). Depress reset button, and alarm status is released. perform zero return. If interlocking is unnecessary, set the contents of parameter no. 66 to “0”.
3000G
Cycle start pushbutton is depressed before performing zero return with the control interlocked for zero return. (parameter no. 06 = “1”). the third and fourth digits of alarm code indicate the axis. depress reset button and alarm status is released. perform zero return. if interlocking is unnecessary, set the contents of parameter no. 06 to “0”.
Applies to
Yasnac CNC Controls 2000G, 3000G
