Sinumerik Alarm 61000 Channel %1 block %2 no tool compensation active
Alarm triggered by following cycles: LONGHOLE, SLOT1, SLOT2, POCKET1 to POCKET4, CYCLE71, CYCLE72, CYCLE90, CYCLE93 to CYCLE96.
D-correction must be programmed before the cycle call.
