Sinumerik Alarm 27225 PROFI safe: slave %1, configuration error %2
Sinumerik Alarm 27225 PROFIsafe: slave %1, configuration error %2
%1 = PROFIBUS slave address
%2 = Configuration error
An error occurred during the evaluation of the S7 PROFIBUS configuration for the specified slave. This is further specified in alarm parameter %2. %2 = PRM header: the PRM telegram for this slave could not clearly be interpreted.
– Mode group not ready.
Check and correct the S7 PROFIBUS configuration.
Switch control OFF – ON
