Sinumerik Alarm 25000 Axis %1 hardware fault of active encoder
The signals of the currently active position actual value encoder (interface signal DB 31 – 48, DBX 1.5 = 1 or DBX 1.6 = 1) are missing, do not have the same phase, or exhibit grounding/short-circuit. The alarm can be reprogrammed in the MD ALARM_REACTION_CHAN_NOREADY (channel not ready).
– Mode group not ready.
– Axes of this channel must be re-referenced.
Please inform the authorized personnel/service department. Check measuring circuit connectors for correct contacting. Check encoder signals and replace the encoder if faults are found.
