Sinumerik Alarm 22320 Channel %1 block %2 PUTFTOCF command could not be transferred
The cyclic transfer of the PUTFTOCF data block (fine tool compensation) could not be performed because the transfer area is already occupied.
Check the part program, in particular with regard to the other channels. Is a data block being transferred by another channel?
