Sinumerik Alarm 22100 Channel %1 block %3 spindle %2 chuck speed exceeded
%3 = Block number, label
The actual speed of the displayed spindle is greater than the value entered in the axis- specific machine data 35100 SPIND_VELO_LIMIT plus the tolerance value specified in machine data 35150 SPIND_DES_VELO_TOL. If the drive actuator has been optimized properly, the alarm cannot occur in the 840D! The alarm can be reprogrammed in the MD ALARM_REACTION_CHAN_NOREADY (channel not ready).0
– Mode group not ready.
Please inform the authorized personnel/service department. Check the setup and optimization data of the drive actuator in accordance with the Installation and Start-up Guide and make corrections. Increase the tolerance window in machine data 35150 SPIND_DES_VELO_TOL.
