Sinumerik Alarm 20160 Channel %1 tool management: PLC can terminate only incorrectly aborted commands
Indication that the PLC wanted to interrupt an active command from the tool management (tool change); or that there is no command active for abort. NCK refuses because the channel status is either ‘active’ (abort is then not allowed), or ‘reset’ (then there is nothing to abort).
For information only.
