Sinumerik Alarm 20092 Axis %1 travel to fixed stop still active
An attempt has been made to move an axis while it is in fixed stop or while the deselection function has not yet been completed. The alarm can be reprogrammed in the MD ALARM_REACTION_CHAN_NOREADY (channel not ready).
– Mode group not ready.
Please inform the authorized personnel/service department. Check the following:
• Has the axis at the fixed stop also been moved by a traversing movement of geometry axes?
• Is a selection carried out even though the axis is stationary at the stop?
• Has the deselection process been interrupted by a RESET? • Has the PLC switched the acknowledgement signals?
