Sinumerik Alarm 17501 Channel %1 block %2 indexing axis %3 with Hirth tool system is active
%3 = Axis name
The ‘Hirth tooth system’ function is activated for the indexing axis. This axis can therefore approach only indexing positions, another travel movement of the axis is not possible.
Please inform the authorized personnel/service department. Correct part program. Correct FC16 or FC18 call. Deselect machine data $MA_HIRTH_IS_ACTIVE.
