Sinumerik Alarm 16951 Channel %1 search run in a program section that cannot be searched
%1 = Channel ID
With the language commands IPTRLOCK and IPTRUNLOCK, the part programmer can identify part program sections that cannot be searched. Every search run in these program sections will be acknowledged with alarm 16951. In other words: When the alarm appears, the user has started a search run (Serupro type) and the search target lies in an area that cannot be searched! An area that cannot be searched can also be defined implicitly with the machine data $MC_AUTO_IPTR_LOCK.
Note: The alarm can only be generated when the simulation is completed during the search run. The alarm cannot be output immediately at the start of the search run.
$MN_SUPPRESS_ALARM_MASK $MC_AUTO_IPTR_LOCK and language command IPTRLOCK
