Sinumerik Alarm 16936 Channel %1 action %2 ALNX not possible due to active dry run
Sinumerik Alarm 16936 Channel %1 action %2 <ALNX> not possible due to active dry run
%1 = Channel ID
This action is not allowed as dry run feedrate is currently active. Example: It is not permissible to activate block search via program test (PI service _N_FINDBL with mode parameter 5) when dry run feedrate is active.
Abort program with the RESET key.
